Sounds like a bad idea to me. Welding creates a lot of heat. Heat changes to properties of metals... allot. Just my .02
PZ
I know some guys have sucessfully done it. In theory, if you make a bunch of small welds evenly spaced around you might make out OK. However, a lot of this depends on your skill as a welder. If you do the Lucky Mod, the skill required is much less. Also, if you opt to weld it, you really should gut it first, like you would with a lucky mod, or there may be noises from the loose and broken parts inside.
Search "Lucky Mod" as Agnem suggested. Several on here, including myself, have done it. Basically you gut your DMF, drill the threads out of six existing holes, and put in grade 8 bolts and locknuts to bolt the two halves together. Total cost: just a few dollars, plus your time and you'll need a decent drill press.
