65sixbanger
If you have the flywheel out, you can actually take apart the DMF and remove the springs and little clutch device it has in there. i had to do this when a pressure plate bolt broke off in there. If I had known I was going to weld it I would have gutted it and welded it on the table instead of upside down.
