Will not start
Cincinnati Guy
Cincinnati, Ohio
I Changed my golden rod filter, let my electric pump fill the filter.it started but ran rough and died. Now I can not get it going again.i even disabled the glowplugs and shot in some eyher and wouldn't hit. It seems to be cranking over fast enough.any hints? I replaced the regular golden rod with a water catcher filter.
dyoung14
Is getting worn out
spencer,tn
Are you getting fuel to the engine?
itsacrazyasian
residentcrazyasian
boca raton, fl
prolly got a butt load of air into the system. might need to crack the injectors open. Ususally when i change my main filter it'll do that. I end up putting my foot to the floor and crank on it and it'll start on the 3 or 4th try.
dyoung14
Is getting worn out
spencer,tn
I have had them were they didnt want to bleed the air from just cranking, mine always had to be pull started
