Will it fit?
Knuckledragger
Payson, AZ
I have a chance to get a 6 speed with built in transfer case from a 2007 (6.0 or 6.4) 4x4. They do not say what truck, F250 or F350. Is it a bolt in? If not, would it be worth the trouble to install it in my 87 F350 4x4 (as a replacement for a T-19 4 speed on 4.10 axle gears). This is the first 6 speed I have seen for sale, do not know how much overdrive it has, if any.
Macrobb
North Idaho
The bellhousing is different - 7.3 PSD and IDI are the same, 6.0/6.4 are the same as the gasser pattern as far as I can tell.
OD ratio is very close to the 5-speeds; I'd probably just swap one of those.
Clutch would be hoohaw to get
Bellhousing different
Likely drive shaft lengths be different
It has a 1st like a PS 5SP ZF 2nd is like our idi zf OD is close to same as our zf
If free n u can manage new shafts n such be kewl...but hardly worth it.
JM7.3CW Eh!
Knuckledragger
Payson, AZ
Thanks! Not even close to free, just wanted to know if it was worth the effort, seems not. Even though I have a machine shop, why spend good time modifying stuff that may not be what I need/want? I'll keep looking.
