chrisk1500
- Joined
- May 7, 2007
- Posts
- 81
- Reaction score
- 0
You may want install new battery cables.....13 years is a lot of time for them to corrode inside the insulation....seen it many times....
Thanks TC! The ground connections for each battery on the engine heads are clean and tight. The third ground (a lighter gauge wire for lights?) is missing. I'll look for it this morning. The starter connection is also clean and tight. Ya know, while I'm at it, I think I'll run a separate ground cable from the block to the frame. My F250 does this at the back of the engine from the bellhousing. When I was working under the truck, I don't remember seeing such a thing. What the heck - couldn't hurt. There's no such thing as TOO many grounds!Have you checked all the grounds? These trucks seem to be especially sensitive to grounding issues.
Good idea! While I'm following up on TC's idea about grounds, I'll also run a voltage drop test across the cable to check for internal resistance. 13 years is a long time and the side post cables were always famous for wicking corrosion down the cable inside the insulation. From the outside, the cables look great; inside, you're trying to pass current thru concrete.You may want install new battery cables.....13 years is a lot of time for them to corrode inside the insulation....seen it many times....
The old pump will have a tag one the front of it. It should say DS4831-5068, DS4831-5067, or a few other variations. Unless it is a 5068 you can put the latest greatest pump on with no problems. If it is a 5068 is you put a new pump on you will have to have the Eprom reburned with later specs.
