Where is the OIl pressure sending unit
Diesel_brad
Dunce
gilbert pa
Well I grounded it out and the gauges moves from PEGGED Zero to 1/32" So it is a good assumption the gauge or wiring is bad
Late_99_psd
Taneytown, MD
Yeah if you unpluged it and you grouned it and the gauge goes through a full sweep then it is your sender ;Sweet
Or are you saying it only moves 1/32"
Diesel_brad
Dunce
gilbert pa
Yes. the gauge went from pegged low to barely on the red in low.
I put a mechanical Sunpro Gauge in. Now you can see the ACTUAL oil pressure
Diesel_brad
Dunce
gilbert pa
Mechanical??? Better hope no oil leaks into interior. haha
I've have one in my pulling truck for YEARS with not one issue. Furels are tight and a grommet where it passes thru the firewall
"cold" at an idle
CaptTom
ca
Ok, I need a new shaft though.
Oh! MAN! That's a bummer.
Can you tell us or pics of seals section?
I have VDO pressure senders on my Detroit, love mechanicals! My tach is still cable drive too. When the cables go bad they sing to me like a mariachi band full of maracas
