Wheel Bearings
mudxtc
knoxville, tn
ok, my early 99 F-350 (04/98) is starting to make a little noise from the wheel bearings......no big deal right (it's only got 205K in her) well, I called around locally and about had a dam heart attack when I got the price for the bearings,,,,,,,,,,,,$437 a piece:eek::eek:
I know I am not the first to have this problem but holy sheep-crap batman!
Does anyone know where the little critters can be purchased at a better price?
Can I take the outer knuckles off a late 99 and swap it out with mine for less money?
mud,
I think all the SD have the unit bearing hubs. Dynatrack has a kit to make the hubs like an older style hubs. The kit is something like $1500 but then they are servicable.
zpd307
Zumbrota, MN
X2, some guys have just changed one side at a time, until the other side goes out.
Double-S-Diesel
parts seller
derry pa
I did get some bearing from fleabay for 250 a pair, but the quality is not there, and they will be replaced by better when funds allow
69oiler
I don't feel tardy
Chardon OH
i changed my front bearing assemblies and rotors over to the 2000 style and never looked back
mudxtc
knoxville, tn
So, basically, all I need to acquire is a set of rotors, pads and wheel bearings for a 99?
Do I need to worry about replacing the 4x4 hubs?
Does anyone make a good lock out hub for this style front axle?
Will the tone ring work with the 99's ABS system or do I need to change something else?
It's days like this that I miss my 73-87 Chevy trucks...........
Double-S-Diesel
parts seller
derry pa
abs is part of the beasing so all is fine
as for the hubs, stock are the same,
as for aftermarkets, warn makes then as does mile marker, I have one set of each.
pads are the same early or late
mudxtc
knoxville, tn
OK, yet another possibly dumb question........... I found an 08 F350 front axle last night that I can pick up cheap from a buddy...... Does anyone know if the wheel bearings/hubs/rotors off this axle will bolt onto the early 99 axle?
bob123456789
