Whats it take???
morepower02
minnesota
Forged rods
MM injectors
fuel system
aftermarket turbo
chip
camshaft
head studs
copper gaskets
o-ring head
water-**** injection
nitrous??
tq convertor and shift kit
traction bars
idm mod
5k mod
guages
intake
exhaust
Just to name a few:sorry:
PSDs_and_5Liters
Huntingtown, Maryland
Originally posted by morepower02
Forged rods
MM injectors
fuel system
aftermarket turbo
chip
camshaft
head studs
copper gaskets
o-ring head
nitrous??
traction bars
idm mod
5k mod
guages
intake
exhaust
Wow, I am almost there, since I already have most of that! ;) cept for the Crew Cab.....mines only a Soopa Cab. :D
DIESEL RACER
Certified Diesel Freak
DPS - MI
Deep Pockets. :D
- Forged Rods (or billet, preferably aluminum for weight)
- HJ 530's :D
- Complete Custom dual feed fuel system (ditch the stock pos fuel bowl)
- Chip to run the show
- Head Studs
- Something to hold the compression in (Coppers, or C-rings, take your pick)
- Upgraded Cam
- Upgraded Valve Springs
- Coated exhaust pipes/manifolds
- Either twin turbos or nitrous and propane, your pick. Or both. -Flame Thr
- Trac bars
- Modded IDM
- ICP Mod
- Upgraded HPOP (not necessary, but it would put you in the DEEP 12s)
- Transmission and transfer case to get the power to the ground
FWIW, my truck ran low 13s and hit a 12.98 once in its current setup when I sold it (water turned on). NOTE - It's a MANUAL :eek: . Guy is making a trip back from CA to Muncie this year to run. It'll be interesting. :D
If I can do that with a manual, it shouldn't be that hard to do with a decent auto.
DIESEL RACER
DPS - MI
Originally posted by Wideopen
yeah but Snowwhite is a rerular cab 2 wheel drive with slicks
And it weighs less than 5500lbs.
I'm not knocking it, but obviously the weight plays a major factor for the truck's ET/speed. :kick:
Ken
DIESEL RACER
DPS - MI
Ken, Are you going to Muncie?
Absolutely! :cool It's close enough for me (less than 2 hrs) that I'll probably drive down there every day.
I'm not sure if my new truck will be ready or not (we're currently too busy for personal projects), but my old one will be there and so far we have 7 engines (PSDs) going in, :rock: so I'll definately have to be there. ;burnout
Ken
JamesF250
Houston, The Republic of Texas
Originally posted by DIESEL RACER
Deep Pockets. :D
- HJ 530's :D
- Head Studs
- Upgraded Cam
- Trac bars
- Modded IDM
- ICP Mod
Could someone explain "head studs" and "C rings"?
Thanks.
pwillis
