wow.......
hell must have froze over.
Mel took the utterance of a Cummins rather calmly.
Talk is cheap.
wow.......
I guess no one likes the nv4500 ?
I saw a conversion kit for our trucks the other day, it was something like $3500
Gheesh! I could get a whole ZF5 and T'case combo out here for alot less than that!
I found this 2003 DT466 with Allison MD-3060/CR 5-Speed Auto Trans locally for $3400 out of a rolled truck... wish i had the guts/$$$ to try it.
Talk is cheap.
theres I believe dt466 for a grand near me. I can get the number is anyones interested in calling on it.
wet sleeves are the way to go i think just my 2 cents anyway
DT 360's are also wet sleeve, unlike a 6BT.
already did . working on a 7.3 now
when you going to build one that will turn more rpm then me
so diesel4me2 what conclusion have u made on your next bada$$ project
the 7.3 is being balanced out to 5000 rpm i figure if the cut out is set around 4700 i should be good. i need to talk to mell about building another pump for me as well, somewhere around a 350cc output
i'm leaning toward something with a nv4500 trans. i'll have a more definitive answer after the holidays
