I think I read that the 99-04 superduties had the 8 on 170.
1st picture... This is the OEM rim from my '88 E350. It fits on my '93 E350 just perfect....just like the factory designed it to.
2nd picture.... This rim came with my '93 E350. It's the spare, however, I do not believe it is original to the truck (it has an ID number written on it that looks like it was put there by a junkyard for identification purposes). I learned the other day that it does not fit. The center hole is too small and wont fit on the hub. The bolt holes did fit over the studs but being pressed for time, I did not go to great lengths to see if the bolt pattern was a perfect match....it could have been "close" but not exactly right.....like I said, I didn't really get into it because of lack of time. It didn't fit over the hub so I rolled it aside and got done what I had to do. It is clearly stamped "Ford". Notice how this rim has a lip or rolled flange on the center hole and the '88 rim above does not. What is the correct application for this rim?
FYI...both rims are 16" x 6".
Thanks for the info.
It is a D60/70 wheel...the sterling has a larger hub diameter...
U can use it for spare..just on front if your not a 4x...![]()
