Ok I've said this before and again it will be stated,
experienced in engine swaps/pull/replacements since was 16yo kid and I personally have pulled well over 200 engines, as I used to work in auto wrecking so maybe have some insight!
Done it all stupid FWD cars, mini vans full size vans, PU, old cars you name it in regular automotive type environment...from yards to shops and all in between...
the key to a simple effective engine pull is to remove as much around the engine as you can, have complete access to said engine, and if going to pull it, and paint it....NOW you can super duper clean the inner fenders, rad support fire wall and frame and add some paint there...
PULL THE CLIP....it's the most efficient use of time bar none!
BAG and TAG all the bolts and where they go in the order they come out....so when you go to install it all you know that each consecutive bag is the next step!
JM2CW
