Black dawg
how many miles till the valve guides should be looked at?
PS...and for whatever reason > my truck seems to burn oil when I fill it to the "full" mark vs when I leave it a qt or so low![]()
Are you checking it hot? 12 quarts of oil expands quite a bit from normal to operating temp. If you fill it to full cold, then run it, you will be overfilled at operating temp. Someone posted an article from a Ford service manual somewhere and how overfilling will cause oil consumption. You may already know this, just thought I'd bring it up again.
Its 12 if you run a powerstroke filter.
