New orifice tube is upside down in the picture.
I couldn't tell is the first time I replace one of those but I put the new one in the same position the old one was. I'll check the manual, thank You.
EZ, how is Charlie? We haven't heard from him in a long time. How come he's not posting "Thanks EZ for fixing my AC"?
I was noticing that too. Did you guys flush that system out before recharging, or at least add an inline filter? If not, you may be getting to do this again shortly.
-------Robert
That orfice tube shows signs of the dreaded black death the compressors see. Is this why you recharged the system? Did you replace the compressor?
After flushing , with a questionable compressor, it would likely be a good idea to add a filter as well. You install them inline between the condenser and the orifice tube . It has a larger surface area and can generally handle the crud left in the system after flushing. Advance , napa etc can order the things, or here
They are also available as units that will screw in between the hose and condenser fittings( I know advance can order those )
-------Robert
Here is what my flush kit looks like.
Thank you for the link. Hopefully the Quart size bottle will work $17.
As opposed to the gallon size $60>
Charlie
Yes, that is what I buy. It is reusable as well, just let the crap settle out, I generally run it through a paint strainer type funnel as well. You can also buy the flush separate once you have the system if/and when you need more in the future. We run this stuff through in both directions, condenser and evaporator, no orifice tube or accumulator, then just blow air through it preferably with a filter/dryer between your air compressor and the air nozzle. Then put it all back together, vac it and refill. Have not had a problem doing this way in over 15 years, with both R12 and R134a!
I have a quart sitting here and the following are the instructions:
"We recommend removing the compressor, accumulator/drier. Disconnect hoses at condenser. Using shop air, blow through the condenser from the inlet to the outlet side. Repeat this procedure from the outlet side to the inlet side. Continue this procedure until all debris is removed.
The same procedure should be used in the hoses and lines and the evaporator. Never blow or flush through the compressor. Using a control flush gun, or simply by pouring Extra Fast Flush into the condenser, allow flush to set 10 minutes. The line and evaporator can be flushed while waiting for the flush to work in the condenser. After 10 minutes, using shop air, blow from the outlet to the inlet of the condenser until all liquid and remaining debris is removed. Extra Fast Flush is compatible with R134a lubricants, "O" ring seals and hoses. This product will evaporate immediately with no residue remaining in the A/C System."
I purchased this can from JCWhitney, so if you buy from there, you should get the exact same thing!!! It is the quart can size as well.
