Uh..Oh......Turbo........
kwazyca
HALF A BUBBLE OFF?
Redding, CA
Originally posted by Renegade
After reading your post Phil - I finally got my butt in gear & did some searching myself to find my high pitched squeal & found it on the pass side /front /top of intake plenum at the long bare spot bewteen bolts.
Glad you posted this as I needed to do this & check it out as my leak was getting to come on at lower & lower boost pressure.
What I used was a can of baby powder & poured it all over all the compressor side fittings of the turbo & then take a quick jaunt down the road & got er boosting fairly heavy till the whine was going pretty loud & then looked under the hood for spots where the powder had been blown off in a line. Sure enough you can spot the leaker as easy as can be.
Cheers
Good Idea!
Wrote that one down for future reference.
Tom
Renegade
HillBilly
Greenup, Ky
That'll work fine & dandy Travis Thanks! I even got a few of those studs like you show on the pic to make up for the thickness of the metal from where I canned that metal lipped thing on the rear of the drivers side valve cover
I'll make me one up to use on the ol girl :Thumbs Up
dieselwiezil
Rosharon, Tx
i am going to have to reject to this. It will REALLY kill your bearings FAST. Its even recommended to plug your intake AND exhaust pipes while towing your rig anywhere.
Snowman269
AKA: DDDENIO
UP, MI moving to DL, MN
Dang, I never thought about towing! I Loaded the wifes Excursion on a flatbed a year ago to haul into dealer when HPOP orings blew out. I bet the turbo was turning! It was an hour drive. I'll remember that for the future, thanks!
Dennis
bigdraft
Strokin..Not ******
Northern Michigan
Guess I have to check out mine now......still trying to figure out why it makes noise. Only does it when I hit the go pedal hard. Sounds just like someone with a real deep voice humming into a fan. I sure hope its not my turbo taking a dump on me. Of course now I have to wait for warm weather again, as it snowed like hell the last 2 days here. That really sucks, 82 degrees one day, 29 and 6 inches of snow the next..........oh well, you know what they say about Michigan....if you dont like the weather, wait 5 minutes and it will change. LOL
adrianspeeder
USAF C-17 Avionics
Dover AFB / Harrisburg PA
This looks like it is good for 150 horsepower :thumbsup:
attachment.php
Adrianspeeder
kwazyca
HALF A BUBBLE OFF?
Redding, CA
attachment.php
Adrianspeeder
Don't knock it till you try it.
It helped me find 3 leaks in the up pipes when I put on my BB turbo. :D
I gained 12 pounds of boost with the leaks fixed. :peelout
Tom
Alleycat
