fiverpuller
Lizard Limo
How does one know when it's time to rebuild a turbo? I figure the obvious signs are if they are seized or leaking. I have three turbos around here...two have a little play and spin very easy...the other one has no play but still rotates ok. None of them leak but I am a little worried about the play. I think on one if I push to the side enought the fins rub on the housing. But I have heard with oil pressure running through them they center right up with no problems.
Also...has anyone rebuilt their own and where do you get parts? It should just be bushings and seals. And as long as things are indexed it should all go back together the same as it came apart and still be balance right? I am lost.
