Turbo Insulation
WarNose
Bay Area, CA
How important is the insulation on the up pipe and down pipe? It seems like I don't see it often. It looks cleaner and is easier to work on without it.
pelky350
Springfield, OR
Wrapping the uppipe helps with slightly quicker spoiling of the turbo, the down pipe I would guess keeps some heat out of the engine bay. I wrapped my uppipe it's seems the benifit me some with quicker spoiling but I didn't wrap the down pipe I didn't foresee much benifit myself in doing it. Neither are technically necessary a lot don't wrap either of them.
hesutton
The Anti-Anderson
Bowling Green, KY
I've wrapped all the hot side plumbing going into and out of the turbo. From the manifolds to the turbine. Have a turbine blanket on there too. Wrapped the downpipe as well. Keeps the heat in and away from my wires, hoses, compressor, and blah blah blah. I can tell ya when I had banks turbos on both my IDI's, the wrapped plumping spooled the turbo quicker on the crew cab than the unwrapped stuff on the F250.
Keep everything wrapped when I swapped the GT3788R on the crew cab. Still spools quicker than the Banks in the F250 and that Garrett is a heck of a lot bigger.
Heath
HS108
Diesel Newb
Connecticut
Are you installing one? If i were installing a kit I would wrap it.
I wrapped my cross over and up pipe while it was installed.
It's definitely not the best wrap job, because I couldn't get the header wrap as tight as I would like, but I do think that it helps.
I also had my exhaust elbow and down pipe ceramic coated to help keep the heat in
I decided to ceramic coat my up pipes,
I completely dislike the look of wraped pipe, but that's just me.
not to mention, if you wrap mild steel, it will rot out faster
I see many people say it will rot faster.
But what if you coated and wrapped?
Never seen factual evidence to support the theory either.
truckonfire
