transmission question and suspension question?!
BIG GREEN 1991
tampa, fl
i have a 1991 f350 non turbo with a e4od tranny. the guy that i bought it from says its been rebuilt and has a shift kit in it. but first gear shifts kinda hard sometimes well harder than all the other gears. could this be affected by my tach only working above 1200 rpm? also im looking into replacing my old worn out shocks with new ones. would like to add maybe an inch or two to the ride is this possible?
Greg5OH
MI
could be. the trans needs to see a good tach and FIPl signal to know when to shift. Poor or out of range signal will cause all sorts of funny problems.
Yes.. The tach must be able to send a proper signal for the trans to shift correctly. Its a simple replacement. Just find the large nut with two black wires on it in the injection pump gear cover. Its of the drivers side of the cover. Use a cresent wrench to remove it. The seal is an o-ring so make sure thats on the new sender. Sometimes the old sender picks up steel pieces from who knows where and it quits working. Might clean it off and see if it works. If there is oil weeping out the copression fitting at the top its shot. Replace it. A ford only item too.
LCAM-01XA
my very own hell
The guys already covered the tach issue, so I'll jump on this - generally shocks do not alter ride height, unless you get special "load-carrier" kind that has either a coil spring or a small air spring built into it. In my experience such shocks do in fact raise the ride height some, but are not too great at providing good ride quality. Which end are you trying to lift anyways, front or rear?
Rear is easy if truck is 2wd, stick a pair of F150 (for 1-1/2" lift) or F250 (for 2-1/2" lift) 4x4 blocks between the springs and the axle. Lifting a 4x4 F350 is best done by altering or replacing the leaf packs as these trucks already have the 4" blocks from the factory and going higher than that is just asking for trouble IMHO (altho Dodge did use some 5" or 6" tall blocks on their 4x4 duallies). As far as brand goes the absolute best IMHO is Bilstein but they ain't cheap, then there is a recent thread on here where Monroe Gas Magnums are also praised.
If it's the front you're wanting to lift a bit, and your truck is a 2wd, then things get interesting - load-carriers (Gabriel makes one like that, #34057 according to AutoZone's website) will do what you want, but you'll have to have the truck realigned, which may or may not work out depending on how she sits right now... Lifting a 4x4 truck in the same manner does not require realigning the front, it's a bolt on and go affair.
BIG GREEN 1991
tampa, fl
okay well today i took the sensor off the injector pump cover and it was clean with no metal shavings and the wires that lead out of the sensor are intact with no exposed wiring.
yes the truck is 2wd
so i would have to buy 2 inch blocks and the same shock will still work properly in the rear? in the front i have a shock and spring side by side. so to be able to lift the front i would have to buy taller springs?
LCAM-01XA
my very own hell
Based on my experience lifting a 2wd F350, the rear shocks may come up a bit short. At least mine did, I used 1" blocks and added extra leafs in the springs to what amounted to approximately 2-1/2" overall rear lift. I ditched my 2wd-specific shocks and replaced them with ones made for a 4x4 F350 DRW, I'd say it worked out good. You will also need new U-bolts, so add another $50 or so to your budget cause of them.
In the front you will leave the coils springs alone, the load-carrier shocks come with their own springs. So it will look like you have two springs side by side, big one is the factory one and small one wrapped around the shock is the assist. You can also replace the factory coils with something stiffer or just taller, then you're not limited to lousy load-carrier shocks and you can run some actually nice ones instead, but I have no first hand experience swapping coils to gain lift so I cannot give you a proper advice on what to use. IIRC some folks used the coils off a newer coil-spring 4x4 F350, like 2004-up or something like that, but I don't remember the details so you'll be doing your own research on that.
