Just put a new radiator in and since I was doing that I figured I would replace all the transmission cooler rubber hoses as well.
What I discovered is that although both the auxilary cooler and new radiator have 3/8 fittings for hose, the pre-formed lines going to and from the transmission don't, they must be 5/16 or something.
It turns out that whoever installed the auxillary cooler connected 3/8 hose to these pre-formed lines as well, clamping the hose tight enough to stay on.
My question how this is supposed to be setup if it were a factory setup? Is the system intended for a smaller hose size?
Sent from my SGH-M919 using Tapatalk
