Towing ?
Cubey
Van dweller
USA
This might be a good choice since it's easy to glance at. As long as you don't go much into red, you are good:
Where is the good place to tap the manifold? near the back cylinder on the passenger side? I guess there's not enough room to drill much past that point.
Wes says that he likes to put a weld in bung right below the flange underneath the driver's side manifold. It's easier to get to, no tapping required, and it's still within 8" of the head.
Philip1
Northeastern Nevada
This is the pyrometer I like to use (although I have the 2000 degree version)
https://www.ebay.com/itm/193754662449
the nice thing about this style, it has a programmable output that can run an auditable alarm to tell you that it is too hot
Scotty4
This is what I did. Works a dream.
William Johnson
Oregon
So running the 7.3 to the yellow or just under wont hurt when climbing ? as long as temps are good of course...They seem to be working pretty hard even at 2000 rpms but i'm thinking because it's my first diesel its just me worrying to much..
Dane Rickford
Markleeville, California
It’s not uncommon for me to run my engine to 3000-3100 when I’m pulling a grade in third gear. The beauty of the 7.3 is that it is a v8, so you safely can really wind it out compared to other diesels. Our engines don’t even hit peak horse power until 2800-3000 rpm, so as long as temperatures are good, I wouldn’t hesitate to push it up too 3000 rpm. I tow a ton of heavy stuff and live in the Sierra Nevada mountains, so I wind mine up to there a lot. Pyrometer and engine temp determine my shift points. Another thing you will probably notice is after a hard, sweaty pull at high rpms, the engine runs real smooth. Honestly there’s not much better things for our idi’s then to work them hard, it really gets the injection system clean along with other benefits. Other then temperature and turbo boost, it’s really hard to hurt these beasts
William Johnson
Oregon
Dane, Sierra Nevada's. My Ol stomping grounds. Hwy 20 between Nevada City and Truckee, Mostly Bear Valley..
Good info on running that motor thanks !!
Dane Rickford
What other diesels are you referring too?
I’m referring to Cummins and Cat other inline configuration diesels. The power band one’ll the Cummins I’ve driven only lasts till around 23-2500 rpm, and that is pushing decently hard with a loaded gooseneck. V configuration diesels wind up a lot higher and carry the wowed band a lot further in my experience
Rayfish
