. It feels the best around 2000-2300 rpm's. Also if I was towing a grade, I can hold 3rd gear 3/4 - WOT without worrying about EGT's to aweful much, while holding it at the govenor (62mph). I feel with that combo I could pull up to about 7-8K pounds at those speeds up a 6% grade. I have no idea what EGT's would do with the wastegate unplugged, and would be leary of holding that much boost over a long period of time. Last time I towed 5K pounds up some 6% grades I had a fairly easy time holding 4th gear, but once you fall below 2000 rpm's (55mph) EGT's would go up and speed would start falling, so a quick shift to 3rd would allow me to accelerate up to 62mph and stay there, while EGT's stayed around 1050*.I've been driving all kinda of trucks for almost 10 years. Yes, I tow with my ZF in 5th gear, but that also depends on teh load, speed and road conditions. If I have a car on the back, and I am on a flat highway, overdrive it is.
If I got a dump trailer with 10 000 pounds in it, 4th gear and never over 55MPH. You don't want to get too hyper with any type of load that is heavier than the towing vehicle...your truck.
Now. As far as lugging an engine. You can, but I DO NOT reccomend it with an IDI. I lug the BIG engines at work, because they are DESIGNED to do that...they have a torque rise that is phenomenal. In an ISX for example, as you are running up the highway at 1700 RPM, and you climb a hill...your torque will become greater as the RPM decreases...horsepower don't move the truck up the hill....torque does at this point.
These IDI engines need to spin fast to work efficiently. Run her off teh govenor all day should you wish, it won't harm it. But it won't do anything for mileage. If I am climbing a hill with my truck...no less than 1600 or so, but even at 1600 I am not full throttle...I don't like beating and pounding on stuff even though these engines can take that kind of beating all day long.
so lugging is being in to high of a gear?
What do you mean by running off governor isnt that at like 5gran/redline?
Yes, lugging is too high a gear. If you're giving it more than 3/4 throttle, and it simply isn't accelerating, or it is slowing down. The engine is "lugging," and you need to downshift to give it more mechanical advantage.
Also your IP has a rev limiting "governor" spring inside it. This prevents it from reving over a certain RPM # (depending on your spring) "running on the governor" simply refers to flooring it and letting the engine rev up to where the governor stops it....(doesn't matter what gear you are in) then driving it there. Apparently our engines don't really mind this... but it still gives me the heebie jeebies thinking about doing it.
