Thanks for the input. Couple questions, I'm not well versed on diesels, so what is cavitation exactly. And why is it that the block heater would crack the block?
Are ther some basic mods that can be done to improve mpg. I'm not looking for speed, but may someday put a turb on it. How do you pick a turbo?
I've just got so many questions. Hopefully ya'll don't mind answering them.
Cavitiation is basically when holes develop in the cylinder walls, or at least thats what I think. The 6.9's didnt really have that problem, but when they came out with the 7.3 idi, which is just a 6.9 bored out to 7.3 liters, the cylinder walls became thinner which was easier for cavitation to occur.
I would say that a DRW truck isnt going to be the best bet if your looking for best fuel economy. What kind of tranny does it have? The C6 brings down the fuel economy a bit compared to a T-19 4-speed. And lastely what kind of gears does it have? If it has 4.10's, then you will want to switch them out to at least 3.55's.
To gain fuel economy you can fab up a better intake, a free flowing exhaust, and an up to date fuel system (ie injectors and IP). Then try to get tall, skinny tires, that will reduce the rolling resistance. You can swap out to 3.07 or 3.08 gears, which ever one it is, that would help out a ton. And lastely you can add a ZF-5 speed, which has an overdrive which would help a ton. Thats all I can think of right now.
And there are, or was, 3 companies that offer turbo kits. ATS, Banks (there going to stop production in December), and hypermax. You can buy them new to have the peace of mind that you have a brand new turbo system, or you can buy them used on ebay, or on your local craigslist or what not. If you want to fab up a turbo kit yourself, then you are going to be opening up a can of worms. You can fab it up, it will be alot of work, and others have done it, but its alot of work. Theres a bunch of guys on here that can calculate what kind of turbo you want, but I dont have any idea how to do that.
