Tire season - using balancing beads
mblaney
Ottawa/Ont/Canada
I thought I would post some details of how I balance my own tires using tire beads (using off the shelf balancing beads and an alternative).
For those who are not familiar with tire balancing beads here is a good video that demonstrates how they work.
https://www.youtube.com/watch?v=eq263AYgyYg
I have balanced several tires using beads and NO RIM WEIGHTS. It is important to note that beads are not recommended for low profile tires (less than 65 aspect ratio) because lower profile tires are more susceptible to lateral imbalances which beads are not able to counteract. Beads are very efficient because they balance at the outer diameter (inside, obviously) of the tire rather than at the rim like traditional weights. Also, no rim weights means you don't screw up the finish on your fancy aluminum or painted steel rims!
The cool thing about using beads is that they balance the rotating assembly, so your rubber, rim, rotor... mud or ice on the inside of your rim. I had a major issue with my wife's Caravan always out of balance; the rims are very flat on the inside and accumulate mud and ice that are always out of balance. After installing beads there is no vibration - ever!
I have used two products:
For our van I used Counteract glass beads from NAPA. To install, I did not attempt to feed them through the tire valve but poured them in before ******* the tire.
For my truck I used an alternative - Airsoft pellets! I use high quality (not biodegradable) bbs in the heaviest density available.
To determine the amount to add to each tire I used this chart from Innovative Balancing:
Note 1: Using too much beads means you are wasting beads but the tire will balance. Using too little means you will not have enough beads to balance your tire. If you have an out of balance try adding more beads.
Note 2: for guys running really ugly off road / howler / cheap tires do some research on how much you will need. Beads are very effective for balancing these tires if you use enough.
Note 3: Never take a bead-balanced tire to a shop to be balanced on a machine. It will not work! You can have a tire balanced traditionally and then add some beads (I would add only 25 - 50% of the recommended amount.
Note 4: Do not use tire slime! The beads need to be free to move around in the tire, adding a product like Slime will cause balancing problems.
I have run these in my truck for two years now and have the best balancing ever. The Airsoft pellets obviously will not fit through the valve stem so I poured the required amount into the tire before seating the bead.
Thanks for reading! :cheers:
jonb96150
S. Lake Tahoe, CA
Re: Note #2 for ugly off road tires.
I used beads for a couple seasons with 35's on beadlocks (back when 35's were considered big lol). They worked very well until the constant airing back up when regaining pavement introduced enough moisture into the tire to clog up the beads. So I put 5 golf balls inside of each tire and that worked good. Good for laughs also because when you stop the balls are still moving and people can hear them and the looks on their faces is priceless!
BrianX128
Pittsburgh
Now if they just won't melt when I seal my tires with ether I'd never need to go to a tire shop again.. haha this is really cool though, if my old manual tire machine that has no compressed air to put new tires on rims that didn't stretch to the edges easy (without red neck unapproved non safe methods) I'd be all over this.
Lance
Staff online
