Tire Pressure for the 235/85/16 10 ply
InnovativeAV
Erie/ PA
so I just swapped out the good tires I just got on the truck....the door states 44 front and 80 rear (cold).....44 front seems low to me.....is that correct.
The new tires are Michelin LTX M/S 235/85/16
direwulf23
Botkingburg (NCen), AR
You'll just have to find out and experiment. How does the tire appear at that pressure. If it is not running on the tread correctly then inflate as necessary
Hydro-idi
Lodi, California
I keep my front and rear's at 50 psi. I do not tow too often with my 6.9 idi.
I keep the tires on my 6.7 psd at 60 psi and I do tow often and loads can be quite heavy sometimes. Of course, the factory does not recommend 60 psi, but the darn thing rides too rough when I pump them up to 80.
ironworker40
NYC Ironworker
nj
I'm surprised that your door tag states that low. Is it the correct door tag for your truck? What is your truck year and model? You should put it in your signature so we can give you better information. My tag states 58 front 80 rear.
I'm glad to see you looked at the tag many people do not and just look at the tire and run what it say's on the sidewall which is the incorrect thing to do on any vehicle. The sidewall psi is the max psi the tire can take. The door tag is what the factory engineers calculated it should be based on the size tire on the tag that originally came with the vehicle. Now it's still not writin in stone. On cars yes, but our trucks the factory looked at max payload, towing, and tires they installed and gave you that psi for the rear tires. So if you have an empty bed and are not towing it is way to high. If you run that 80 psi in them they will wear the center of the tire out. I find 60 psi is good unloaded. That tire psi info is also in any owners manual too.
InnovativeAV
Erie/ PA
I took that off my 92'.....the 93' 7.3IDI has had the cab replaced before with a 96' f150.....My 92' had 44 for the front but that is also a gasser so I will probably bump that up to 55....the rears I set at 65....I have about 500lbs of sand bags in the back
ironworker40
NYC Ironworker
nj
Well I thought something was wrong with your sticker. Mine is 58 psi and is its a 9200 gvwr direwolf23 has 55psi and is 8800 gvwr thats why they are different.
madpogue
Madison, WI USA
^^^^ That '95, being a PSD, is a MUCH heavier truck. The door jamb sticker on my '85 says 44 front, 80 rear.
olsen726
