If the ferret seems steep, you can get a rental J3300A (it times both pulse and luminosity method) from Icanfixall.
I prefer the pulse method that the ferret uses. Mostly because that's the way I've done it, and had it work.
the 9/16" wrench you can make, either by grinding down a HF offset wrench. Or torching a normal box end, and bending it to the correct offset. Then grinding it down. To get onto the nuts, it has to be really really thin, and narrow. How much grinding you need will be pretty obvious by looking, and the top nut you can get to easy with a strait wrench to do a grind and testfit. Also, if you have one already, you can use a 20" or bigger C-wrench in place of the IP wrench, just be very careful how much pressure you use.
Just so it gets said:
NEVER NEVER EVER!!!!!! start your engine unless your IP is torqued down to spec. You will destroy it.
For the pulse method, timing reading is taken at 2000 rpm's with either the engine warm, or the cold advance disconnected.
