Okay, quick recap. I had a problem in the past with the front wheel bearings on my truck (Dana 50 front axle). A tire shop found that the bearings were loose, and repacked them. A friend of mine checked the wheel bearings a couple of weeks later to find them still loose! With my assistance (I wasn't doing the actual work since we were in his shop at school and I technically wasn't supposed to be there), he re-adjusted the bearings following the Ford factory specs, and they still came out loose! He then left them torqued.
At this point, I figured that the bearings were shot, and elected to replace them when time allowed. Well, that time is now. I've got new bearings, new races, and heaven knows what else...and I went to get one hub secured. The Ford shop manual says this:
Tighten inner locknut to 50 ft-lbs to seat bearing.
Back off inner locknut and retightento 31-39 ft-lbs.
While rotating hub, back off locknut 135° to 150°.
Assemble lockwasher and outer locknut and tighten to 65 ft-lbs.
With brand-new bearings, and following those instructions, I'm still feeling play in the hub. Now, with the lockwasher in place, I'm assuming that putting the outer locknut on won't affect the pressure that the inner locknut's putting on the bearing, so I'm at a loss at this point.
Did Ford mess up the instructions? Or what am I doing wrong? I imagine that, since I can feel the play, it's out of specs...
I'm wondering if I'm supposed to reach in and tighten up the inner locknut by hand after backing it off...
Any thoughts? Thanks!
