I am going to be replacing the entire tie rod/draglink assembly on my truck./ I am assuming I will need new Adjustment sleeves , passengers tierod end(outer) , and the draglink(inner, this part attaches to the pitman arm, and the drivers side tierod) and the drivers side outer and inner tierod. I have a crew cab 2wd, And I am finding that the parts for a crew cab are more expensive, and also, less available. I wondered if it was possibleto use regualr cab parts since I was replacing everything, and since the pitman arm is the same regardless of the cab, I thought this would work. The difference I can find is the size thread used on the crew is 1 inch, and on the standard cab is 22mm......AnyOne an expert at suspension?
