gatorman21218
On the hard line connecting the filter to the IP I cant get the olives out. They must be original because they are so hard in there that after 30 minutes of picking at them with a small screwdriver and a steel wire its lilke I have gotten nowhere. Is there anything I can soak them in to loosen the rubber up? I need to go find one of those dental picks, but again its like they are plastic and glued to the nut.
Also how best should i clean the injector holes? i went and got a gun cleaning kit, but it doesnt work that great, there is some pb-blaster in some of the holes too where I had to soak them. I guess what Im asking is how clean should they be? All the copper washers came out and I plan to crank the engine over without the glowplugs to clear out any pb blaster or brake cleen that may be sitting in the precups.
