Thanks all thats the info I needid. Question on the ranger, The manufacturer states its max torque is only about 435 lb ft and if it lets go everything stops is this tough enough. Are they also very noisy? I like it in theory. The ZF is sounding very attractive right now.
435 ft lbs is PLENTY. I seriously doubt that any "normal" 6.9/7.3 - even with a turbo - is going to get terribly close to that number. The stock ratings on the NA 6.9/7.3 IDIs are in the 300-320 ft/lbs range IIRC, and the turbo does more for HP than it does for torque.
As for noise, I can't really say from personal experience, but from what I have read they aren't appreciably noisier than the stock T-19. Certainly less noisy than a ZF with a SMF conversion like mine.
If I had it all to do over again, I would have kept my T-19, installed the 3.55 dually rear axle a guy offered to sell me for $300, and then installed the Ranger OD in my own truck.
It would have been less hassle and less money than swapping the front to 4.10s and then installing the ZF-5. It would have got me almost as good of a gear spread (20.82 final drive in 1st & 3.15 final drive in 5th with the ZF, vs. 16.70 final drive in 1st and 3.55 final drive in 4th with the T-19/Ranger combo), plus I'd have 8 forward gears, 2 reverse gears AND a twin-stick (how cool is THAT!?!). Instead I have a slightly wider spread but only 5 gears, and a slightly noisey ZF-5/SMF conversion setup.
Unfortunately I didn't have the Ranger box available to me at the time so I went the route that I did, BUT, I think the other setup would have been a lot cooler and more flexible. Now if it were possible to install the Ranger with my ZF-5, THAT would be REALLY cool - but it isn't since the Ranger goes between the tranny & bellhousing and the ZF doesn't separate at the bellhousing...
