Thinning WMO: Diesel or Kerosene
cleithau
Northern Michigan
What works better for thinning WMO, diesel, or kerosene? A lot of people seem to be using kerosene? Why?
On the post 100% WMO there was a guy mentioned from Iceland who was running 100% WMO and blending 10% premium unleaded so it would start fine. Is this a bad idea, or should it work?
hheynow
the misanthrope
SF Bay Area
Kerosene has a lower auto ignition temp and lower viscosity than diesel so it thins better and ignites at a lower temp.
Mr_Roboto
Elyria, near Cleveland Ohio
Running premium is a waste of money. In a diesel either 87 or 92 will ignite the same, since the compression is far above either ones' auto ignition temperature.
Gasoline is more dangerous because the fumes are more flammable. I'm not saying it's bad, you just have to remember what you are dealing with.
cleithau
Northern Michigan
Besides being more dangerous, it seems far less expensive to use since a much smaller quantity will thin a lot of WMO. Other than the slightly increase risk is there any other disadvantage?
At a 5% in summer blend and 10% in winter that would amount to $0.225 per gallon in summer and $0.45 in winter. Not too bad.
Also it hit me that a marina would be a better place to get WMO from because there would be almost no chance for brake fluid contamination or antifreeze contamination since boats don't use any.
subway
be nice to the admin :D
York PA
i only add oil to my regular diesel for my regular tanks and run 100 WMO on my aux tank nothing else added.
miy BIL claimed adding Kero to his WMO helped more and ran better than adding diesel. he was running about a 75% WMO in his powersmoke.
crispy74
