Macrobb
The speed you are going to be going matters:
With a 5-speed manual, 4.10 gearing, you are going approximately 2050 RPM @ 60. 2550 @ 75 in top gear.
With 4.63 gearing, 2315 @ 60, 2880 @ 75 in top gear.
With an E4(uh-oh)D, 4.10 gearing you are going approximately 1912 RPM @ 60, 2390 @ 75 in top gear.
With 4.63 gearing, 2162 @ 60, 2702 @ 75 in top gear.
Now, with a turbo, that's still in the power band, at both places... though my canculations and personal feelings suggest that aiming for about 2400 RPM would be a better number aiming for in top gear.
Remember, you can always downshift if you need more power. If you have a 5-speed(or E4OD), and you can't be in Overdrive while towing heavy...So?
That's what it's there for: you plan on top gear being your cruising gear, with lower revs meaning better economy, and having the ability to downshift to get more power if needed.
Overall, with a 5 speed, 4.10 gearing makes sense. With a E4(uh-oh)D, you can probably go a bit higher numerically and still have a truck that isn't screaming at you.
Here's a great link showing all the gearing combinations:
https://www.gearvendors.com/fdrive.html
To calculate RPM( with stock tires), I'm using a number of final drive ratio of 3.12 = 2050 @ 60mph.
Aw... I really want to see what you make!my rig will most likely never see a dyno.
Nothing like the NWDC coming around your area? Public dyno events?most of the chassis dynos around here are ran by people I don't much care for.
so ill stick to my own little world lol
