the cleanest coolant filter ive seen to date.
jwsfarrier
Molalla,OR
Ive been on the fence about a coolant filter. That just made up my mind. Thanks for sharing the info!
Part of the reason for the clean, sleek lines, is this is "designed" for use with a 6.0. Underhood space on a 6.0 is at a premium. Most of these kits are designed to be mounted on the passenger side of the radiator, on the core support, between the radiator, CAC Piping and the passenger side battery. That is one of the few places there is even enough room to mount a filter head and a filter. I've been looking at one similar, but that price is much better. Thanks for the link.
i didnt even realize it was for a 6.0
think it will make my headgaskets leak??!??
;Poke :D LOL :fight:
dont give me a vacation Scott!!!
That's nice. I think mine will be pretty slick as well. I'm doing some test bits right now. :sly
Lol I was gonna say something at first, but I thought you knew when you posted it.
Mishimoto makes one also. Gives you a choice on hose color too.
GreenEggSam
Okanogan, WA
I bought this system. On the 7.3 92 F250 with AOD and the heater return hose with the 1/2 inch reduction branching to the lower right radiator barb fitting, any reason not to hook up the 1/2 inch tee supplied in this kit directly in place of the original equipment 1/2 inch hose section in that position? It would use the T-hose originally designed for the degas bottle on the 6.0? The other line hooks right into the heater inlet hose 5/8 inch. I'm building a bracket to hold it next to the fuel filter. Thanks Sam
Special thanks to Al (Riotwarrior) for making the trip from Canada to meet up and help me out with the oil cooler.
im not running that T either.
i dont have i completely together, but im running it straight to the heater core
GreenEggSam
Okanogan, WA
That was my plan at first, but since the hose supplied in the kit is 1/2 inch, thought why not use it there instead of blocking off that 1/2 inch barb? It would be easier and maybe the torque converter would warm up sooner as Ford intended?
torque converter?
my left foot is far from sluggish :D
i wont be using the hose provided, it will clash with my engine compartment lol
GreenEggSam
Okanogan, WA
That is beautiful. Don't blame you for junking those baby blue hoses!!! Nice tub work on your fender wells....
thanks.
thats not the engine ill be using tho.
that was for mock up of everything.
heres the engine ill be running.
dordtrecht5
