Farmer Rock
I figured I will just post this today since I need a few opinions.
I will be doing a lot more work to the truck either way,so stay tuned.
Rock
Beagle Pup is a 1987 International S1600 6.9 idi 5 speed spicer.I absolutely love the truck,it only has 137k miles and everything works perfectly.When I bought the truck last year,It wouldn't start for nothing,so I completely re-did the GP system and converted it to manual GPs because it looked like Rube Goldburg snuck under the hood with wire cutters.so it has all new cables,wires,new GP harness,relay,switch,etc.,also converted it to electric lift pump.The truck starts right up on the first revolution in the coldest weather the hills of PA throw at it with no block heater and double cycling the GPs.This brings me to the painful question.I have a chance to buy a dt360 5 speed bus from our church,and that thing has a lot of torque and power,and started right up after 3 years of sitting.It would be pretty easy to swap the motor and tranny from the bus into my truck,but not sure if it's worth it or not.I plan on using this truck for heavy towing and could definetly use the upgrade,but I would hate to tear the perfectly good motor out. I'd appreciate your thoughts and suggestions.I will be doing a lot more work to the truck either way,so stay tuned.
Rock
