Testing vacuum (hard brake pedal)
94250turbo
Detroit
Do i just buy one of those vacuum testers at autozone and hook it up to the brake booster? What should the readings be? Also do i just test it at idle?
firehawk
Dallas, Tx
I used a large vacuum gauge and T'd it in to the brake booster. My vacuum was low, but a new vacuum pump fixed my problem with the brake pedal.
fuzzy1626
Taylorsville,NC
The vacuum gage installed in my truck stays on 22hg even at idle unless I step on the brake pedal.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
You should be able to push down on the pedal with the truck off for a minute with minimal loss of vacuum. There is a list of tests in the factory service manual that are very helpful in diagnosing vacuum problems.
FarmerFrank
Blairsville, Pa
Not to hijack a thread too much, but is there a rebuild for a vacuum
Pump??
Is it just a diaphragm that goes bad inside?
94250turbo
Detroit
I unplugged the booster hose from the manifold and put the vacuum gauge in its place. The gauge was between 20-25 hg . Was that an acceptable method to test my vacuum?
94250turbo
Detroit
Could it be the brake booster? When I would apply the brakes there would be a "woosh" noise.
madpogue
Madison, WI USA
If you have that good vacuum at the distro box, then yeah, the next prime suspect is the booster.
vegas39
las vegas, nv
Your booster is bad. I went through 4 or 5 autozone rebuilds before finally getting a good one. Every time I hit the pedal, it was kinda hard to push and they all sounded like I had air brakes.
94250turbo
Detroit
I was about to buy the brake booster and decided to check the vacuum again and it is quite low. Where is the low vacuum switch located so I can do a few more tests.
4x4manonbroke
Diesel Master
Tacoma Washington USA
I installed T about 12" from pump where it goes to all the A/C stuff and then over to the Brake Booster, mine was 4hg ... talk about hard to stop ... lol
Just follow the lines. It has a two wire plug.
Should be drivers side fender liner under the battery on obs trucks.
Same but passenger side on bricks.
Sent from my SM-G900R4 using Tapatalk
94250turbo
Detroit
Can someone guide me on what puller i need to use for the vacuum pump pulley? Does harbor freight have one that will work? Anything i need to know about pulling it off and putting it back on?
Power steering pump pulley puller.
Say that 5 times fast. Lol
Check it for oil before you put it on.
JU57US
Staff online
