Well that's the best idea.
Don't wanna put it on and have it seize up, do ya?
Sent from my SM-G900R4 using Tapatalk
Ok thanks. Did you have to pull the pulley with the pump on the truck? There isnt enough room to get my mounting bolts out. They hit the pulley.Just get the pulley even with how it was. Lol
On the back of the pump will be a small bolt plug, remove it to check the oil.
I can't remember the best thing to use in it. Maybe was mmo?
Yeah pull the pulley with it bolted down, then put it back on once it's bolted down. Lol
Some pullers won't have enough room though.
.. Cant remember now ???Did you replace the vac pump on the truck in your sig? Maybe ours are different. I do not see any way to get the pump off without pulling the pulley first.I pulled mine off the truck and pulled the pulley in a vise, and did the re-install on the bench as well...
A P/S puller works best from my understanding .. I think i thats what i used .. that was 5 yrs ago ..... Cant remember now ???
Gotta use a open ended wrench.
I think that's actually how I did my brothers 93, because the puller wouldn't fit in there.
Generally, do new pumps come pre-oiled or not?
