94250turbo
Do i just buy one of those vacuum testers at autozone and hook it up to the brake booster? What should the readings be? Also do i just test it at idle?
Could it be the brake booster? When I would apply the brakes there would be a "woosh" noise.
I was about to buy the brake booster and decided to check the vacuum again and it is quite low. Where is the low vacuum switch located so I can do a few more tests.
Check it for oil? Im supposed to lube the new pump?Power steering pump pulley puller.
Say that 5 times fast. Lol
Check it for oil before you put it on.
Sent from my SM-G900R4 using Tapatalk
