Hello everyone, today we will be doing a compression test of a 7.3 IHI/Ford diesel engine in my 91 F350 4x4 RC truck. AKA White Rhino!
NO HATERS please
remote starter switch, comp test kit (TU-15-53) as seen here http://www.toolsource.com/diesel-compression-test-p-95945.html and some 1/4" drive sockets and extensions etc for removing GP's and installing comp tester adapters, also note pad for recording the test data!
Now prepping for comp test, start by removal of air cleaner and GP's wires
Here I"m indicating a GP with bullet connector removed
Fuel stop solenoid wire that MUST be disconnected
FOR SAFETY SAKE AND SO I AM COMFORTABLE, I elected to disconnect the FSS others may not this however is my choice and this is my thread!
Hard to see but now FSS is disconnected
On my starter solenoid this is the wire to disconnect for the remote switch to be used
connect the remote starter switch to BAT +
I'm using a Magnetic tray to hold GP's
GP 1-7 on Left 2-8 on Right
cyl 4 & 6 look damp here pointing to #4
close up 1-7
Close up 2-8
I've got video coming as well so stay tuned for more to come!
Thanks for looking
Al
NO HATERS please
and finally with the switch connected
close up 1-7
Close up 2-8
Thanks for looking
Al
Thats a great job for Auto RX for sure. Now for something many need to look at on the pic number two. See the two bolts that holds the intake to the head.. See the number 2 cast into the head. Good... Now a'll know where to look for the cylinder numbers instead of guessing what they are. Members that have rented my timing meters have connected to all kinds of cylinders thinking they were on number one or four. Some of you will have to clean off the intake to see these numbers but at least now you have actually seen where they are. This message is not to imbarrass anyone. We al make mistakes. I made a big one a few weeks ago timing dragrags truck. I couldn't get my repaired meters to work correctly. So I went home and tested all my meters.. Well none of them worked... WTH is going on. They are sitting here in a cool dry place and they are broken. So I start testeing them again and finally figured out I was pressing the wrong rocker switch... Imagine that. Me that knows more than most. That has taken these meters apart and replaced parts. Talked to the only repair guy in the country has made a mistake... Well it happens.
