GENIUSLOERTS
where is the TCM located on our trucks? I've been searching for the past hour to find out where it is. I am bout to hit up a junkyard for a turbo TCM , and trans fluid level tube
I was told the programming was better for the idit, but I was also told the ecms were not interchangeable.
PSD's do not have a TCM. Ford changed to a PCM9 Power train Control Module). The PCM controls both engine and transmission in one unit.
PCM and TCM are not compatible. Two totally different animals.
Do you know if the e40d tcm are interchangable through the years?
