I spent a few minutes and speced out a F-650 crew. Hopefully this pastes in OK>
Window Sticker 2007 Ford F-650
Crew Cab XL
Major Standard Equipment
Cummins 5.9L I-6 OHV w/diesel injection 200hp
5 speed automatic trans w/OD
4-wheel ABS, hydraulic disc brakes
10.0R22.5 highway tires
M+S rear tires
Air conditioning
Tinted glass
AM/FM stereo
Variable intermittent wipers
22.5" x 7.5" white steel disc wheels
Tachometer
High back driver captain seat, mid back passenger two person bench seat
Full folding rear bench seat
Vinyl seats
1,250 Amp dual batteries
130 Amp alternator
Side steps
45gal. right front fuel tank
Multi-leaf rear springs
8,500lbs. front axle capacity
17,500lbs. rear axle capacity
8,500lbs. front spring rating
18,500lbs. rear spring rating
12.64cu.in. frame section modulus
50,000 frame yield strength (psi)
194.0" wheelbase
84.0" cab to axle
49.0" axle to end of frame
282.0" overall length
Heated fuel/water separator
Transmission PTO provision
Right mounted horizontal muffler, right mounted horizontal tailpipe
Dual electric horn
Selected Optional Equipment
Base Vehicle Price $51,922.00
19,000 lb. Single-Speed - Spicer 19060S $366.00
3.70 Axle Ratio N/C
Air Brakes - Straight Truck w/16.5x7.0 Rear Brakes & Traction Control $1,646.00
Caterpillar (7.2L) C7 300 HP @ 2200 RPM, Governed @ 2400 RPM $7,012.00
Engine Exhaust Brake - Jacobs w/Caterpillar $915.00
Fuller FS0-8406A, 6-Speed Manual, Overdrive -$1,598.00
Synthetic Transmission Oil, EmGard 50W - 1 thru 21.99 Pints Included
Two-Plate, Stamped Angle Spring, Ceramic, 14" Diameter, Adjustment Free Clutch $457.00
Body Builder Wiring - To End of Frame $134.00
Tank - Steel (Shallow) 65 U.S. gal./45 U.S. gal. Combination - Total Capacity 110 U.S. gal. (416 L.) $593.00
22 Gal. Dual Tank Fuel Fill. Mandatory Charge Applied, Based On Tank Selection $0.00
Air Ride Driver, 30%, Reclining, G-Grain Vinyl w/G-Grain Vinyl Insert $463.00
Passenger Air Ride, 30%, Reclining, G-Grain Vinyl w/G-Grain Vinyl Insert $415.00
Rear Bench, G-Grain Vinyl w/G-Grain Vinyl Insert Included
XL Trim Package N/C
Privacy Glass/Sliding Rear Window $244.00
Horn, Air, Grover - Black, Single Trumpet $55.00
Mirrors, 2 Auxiliary Convex - Stainless Steel $43.00
Mud Flap Holder Without Flaps $79.00
Mud Flaps, Rear $67.00
Radio CDX6 AM/FM Stereo - Visteon w/6 Disc Changer, No Cassette $561.00
Steering Wheel - Two Spoke, Black Leather Wrapped, 15.5" Dia $85.00
Wheels, Front 22.5x8.25 Polished Aluminum Disc, 10-Hole $567.00
Tires, Front Two 11R22.5G Goodyear G395 LHS (504 rev/mile) $24.00
Wheels, Rear 22.5x8.25 Polished Aluminum Disc, 10-Hole $1,171.00
Tires, Rear Four 11R22.5G Goodyear G395 LHS (504 rev/mile) $24.00
All for a grand total of $66395
I would tweek a few other things before ordering such a thing. Probably would spec the rear tires for something with some traction capability. I wish they had 2 speed rear axles with something like 3.50 and 4.33 as the split. I don't know if IH has a built it online but I will look. A CXT would be awefull cool though.
