if you add springs,consider overloads.
if you want more mains,keep the two long ones at the top stock and put more under those.
by keeping just the two long ones,these can still flex and absorb the bumps.
i took out the second one up,and put two f450 leafs in its place,then used a custom 3 leaf over pack.
i still have my ride quality empty,and have a 6 main/3 over combo.
she takes a nice load.
you need:
new custom length U-bolts.
new custom length center bolts.
since you need new hardware anyway.this is the time to head to the salvage yard and score:
overload perches
at least 1 overload (per side)
don't go through this,and not install an aux.save up until you can do it all at once is my suggestion.
if your on a very limited budget,then:
remove your springs.
separate them.
separate the others.
leave that very bottom flat one alone,and set it aside from the donor.
double up the next three (from the bottom.)-double up just the next two if you want to keep a more factory ride.double up the very top too if you don't care about ride quality at all and want max payload.
install NEW U-bolts and center bolt.-- this cannot safety be avoided.budget for it,or don't do it imho.
good luck sootman.
U-bolts cannot safely be reused because once tightened,the threads becomes stretched.please do not try and reuse them for you safety and others on the road.
just before my dump bed repair/final installation,i added these:
