Surging? Burst of power??
AcIdBuRn02ZTS
Indiana
Gotta give you crap... it's typically me being too slow so I have to jump on the opportunity when it arises.
Not by a liquid. Lol
Maybe someone else can explain it better.
Need a fluid engineer. We had one, but he hasn't been on in awhile.
morgankshaw
Sacramento, CA
This is very interesting. I'm thinking air may be getting in from the fuel filter it looks a bit wet. Maybe just needs tightening. It's new.
IF I had air in the lines though wouldn't I have starting issues?
Truck fires right up every time.
Or is it possible air sneaks in under hard load??
Well the faster the engine turns, the more the lift pump is working.
You could just have a restriction somewhere.
morgankshaw
Sacramento, CA
Is it leaking where the filter screws in it on the top of the filter housing?
The filter just looks a bit damp on the sides but it's not dripping. I'm using an electric fuel pump. I guess I'll have to snap some pics
morgankshaw
Sacramento, CA
Definitely leaking from bottom of the filter... it seems tight though... is there a better option or should I lubev he seals and tighten it back on?
Also pics of my fuel pump.
Thewespaul
Bulverde, Texas
Seals should be lubed for it to not leak, you could also be running out of fuel pressure at high load with high rpm
pelky350
Springfield, OR
When my cold advance is on it will cause the same surging issue. Mines on a switch. Possibly the cold advance stuck on or something telling it to be on
Jimacho
