BigRigTech
Diesel junky
I know about battery cable, see my sig.....The hookup is going well, should be making smoke tommorow if all goes well.
Do you know if the idi manifolds can be flipped upside down, or right to left?
Clearance in the engine bay of a truck is irrelevant, I just want to know if it can be done.
I use 3/0 on diesel cars. You'd be amazed at what a difference it makes in how fast the starter spins.
You can get zero corrosion fittings with crimps, you don't need solder . Been doing it for decades. Just work some conductive grease like NoAlox into the cable end strands, crimp it and seal with heat shrink. It will outlast a set of factory cables
