Lonewolf182
When I did my motor swap I also took the tilt steering column from the donor truck.
That truck was set up to start by using a push button.
The key switch from the original column works and came out pretty easily but the switch in the tilt column is stuck.
I turn the key to the 'on' position, push in the lock pin and try to pull the switch, but no luck. It only comes out about 1/16th of an inch.
I've wiggled, jiggled, twisted and gently pried but still no luck.
Any ideas folks?
Any ideas folks?
