Stranded need help. Battery drain stuck glow plug relay?
IDI73
Las Vegas
Hello all my family and I are moving and my 93 idi f250 has got us stuck in Cedar City Utah. So everything was fine. Stopped for 30 min came back to zero power anywhere. Not even a dome light and nothing when trying a jump either. Replaced with two new batteries and now I can start the truck but the passenger side positive battery cable gets extremely hot almost smoking tracing the heat past the passenger fender relay the power wire going to the glow plug controller is the only one that is burning hot with batteries connected and key off. I feel like I have a major power draw even with the key off. You figure my glow plug controller relay is stuck closed keeping the glow plugs on even with key off? It’s summer here can I just unplug the glow plug relay and fix it later to be on my way? I tried taking the glow plug power cable off the passenger fender solenoid but then the truck wouldn’t start. It seems that power goes to the fuse box not just the glow plugs? Any help is appreciated
Philip1
Northeastern Nevada
It is possible to unhook your glowplugs and run it so long as you cover the end of the cable. At least unhook them and see if you still have a massive draw or not
Selahdoor
Index Wa
I'd unplug all the GPs and tape up each connector so they don't ground out.
Not positive, but if the controller is kakked, I suppose it's possible to ground out that way, instead, and pulling the connectors won't fix it.
ih8minimumwage
Eugene, OR
Unhook it from the controller and if batteries can be jumped, be on your way.
Either turn key on and momentarily plug in the controller if it needs assistance to start in the AM, or a trip to the auto parts store and we can get you rigged up with a manual push button if needed. That is if your GPs didn't burn out before the batteries did.
Fixnstuff
Kitsap County, Washington
This has happened to me before but I was able to make it home.
This is what I think: At the two large terminals on the controller relay: One is where that bent flat bar resister is connected. That is the secondary side of the relay where the current travels from the relay through that resister to the glow plugs. DISCONNECT THAT SIDE at the large terminal on the relay and move that resister out of the way. There is a bolt that holds it down at the bottom end which connects it to the glow plug harness and you'll need to loosen that bolt to move the resister to the side, or you can just take the resister out of the circuit and reinstall the bottom bolt. Now the glow plugs and that resistor are disconnected and out of the circuit.
When a GP controller relay sticks closed that resister will consume a huge amount of current and get extremely hot! Hot enough to melt through the plastic cover that goes over the top if you still have the cover. The hotter it gets, the more resistance it has and the more current it consumes from the batteries. That will drain your batteries faster than the glow plugs. IT WILL ALSO PROTECT THE GLOW PLUGS FROM BURNING OUT.
The other side of the GP relay is the primary side which is connected to Battery voltage. I THINK (I'm not certain) that side needs to stay connected for the ignition key starting circuit to work.
Otherwise, if that side is disconnected you can probably tun the key on and jump start it across the terminals of the starter relay on the fender well (If that's where your starter relay is located)
I've never been able to start my truck with the ignition key after disconnecting the power supply wires that go to the primary side of the GP relay, by disconnecting them at the starter relay. That's why I THINK that the GP controller relay needs power to the primary side so truck will start with the ignition key.
LAST, from memory only, I think there is a small wire with a ring terminal connected to the secondary side of the GP relay. It's from the controller. I think it's white? I don't know if that wire needs to be connected to the secondary terminal or not for the truck to start with the key , but what I described disconnects the major load of the glow plugs and that resistor from the circuit so it won't kill your batteries.
Later today I'll post some photos and the story of my experience with this. I cut open the relay as part of the diagnosis so you'll be able to see he insides of one burnt relay
HEY, it could have been the controller that failed and caused the issue.
IDI73
Las Vegas
It was the glow plug relay it had failed shorted closed so I was powering glow plugs even with key off. This may have been caused by failing batteries but unsure. We are back on the road after replacing the glow plug relay
