the speedo on a '88 may run off a gear in the trans, so tire size changes will affect the speedo reading because the drive line revolutions are different between the tire sizes. on a '93 the speed sensor reads the tone ring in the rear end, so it sends the signal for the correct revolutions from the tone ring, your speedo should be less than 5 mph off
