1991f2504x4
I'm considering purchasing a 1993 7.3 factory IDIT, deleting the turbocharger, replacing the injectors with N/A units and using a fuel pump calibrated for 174HP @ 3000 RPM?
This engine has keystone piston rings. Is it necessary to use a turbocharger on this configuration to ensure the piston rings seal properly?
Intended use is a marine engine on a 25' boat. Have the full factory marinization kit for marine use from Peninsular Marine including engine mounts, water cooled manifolds, closed cooling heat exchanger, raw water pump.
The thinking here is the beefier internals, larger oil cooler, anodized pistons and Inconel exhaust valves will contribute to increased reliability when running all day @ 2700 RPM.
I intend to go to remote places with the boat so, reliability is paramount.
