Speedo pegged to the right
Be pretty helpful to post what year truck.
Brick nose are cable driven. Obs are electronic.
Mobile users don't see your sig typically. Is it the 90? It's cable driven. Can't tell you much more. The speedo mech must be bad if the odo works. That pretty well rules out the cable.
no mufflers
rhode island
there is a small spring in the cluster that returns the pointer back to 0 mph. that might be broken leaving it in lala land. those clusters are super easy to take apart so if you feel adventurous and dig into it in sure you could find the problem.
austin92
Brazil. IN
Have you tried letting off the throttle? Lol
1983 f350 6.9 zf5 2wd srw single cab long bed. Facet duralift, optima red tops, bfg all terrains, 4" exhaust from y pipe back, autometer z series pyro, pump turned up 2 flats
Your going a lot faster than you think you are. Just had to.
witch is good without a fuel gauge
Witch es fly on broom sticks. Oh hell, a little humor each day is ..............
Your speedometer is driven by a cable, the speedometer needle is moved by a rotating magnet, the resistance to the magnet is a clock spring, as said, it's broke or disconnected.
ntjapkes
