Speedo cable gear
The_Josh_Bear
Western WA
In my experience it's a three mph change between gears, mine was 10 mph I just kept buying them until I got it right, I should have just bought the whole set.
I ended up buying a no-name brand eBay kit years ago for my larger tires and 3.55 gears. I got the kit because I wasn't sure which gear I needed for sure and it was only a little more than the single gears anyway. I'm glad I did!
I need to change gears to fix the speedo reading, too. In the past, they were color coded (for number of teeth), do not know if they are anymore.
They still are, but also best to count teeth as whatever you buy is usually aftermarket now. Maybe entirely.
One thing i've learned about these trucks is the speedometer, and Odometer can give totally different readings. MY speedo says I'm doing 80 MPH while my phone GPS says I'm going 60 MPH and my Odometer is counting like I'm driving 55 MPH. You might change the speedo to the correct speed but what does the Odometer have to say about that?
That's nuts! I've never thought about that ever...MAYBE I'm not really getting 13-14mpgs after all!? I'll have to check sometime, thanks for the tip! I don't care about the total miles driven as it's a rollover anyway, but having accurate MPG's is something I always like to know.
And ideas how can the speedo be different than the odo?
WrenchWhore
Lake Havasu City
@The_Josh_Bear I'm not sure how to correct this yet as I haven't dove into the threads. All's I know is when I corrected my 84 bullnose speedo the Odometer was off by good amount. My current 87 truck has a fairly accurate Odometer. After driving 500 miles it was probably sitting at 485 miles counted. but the speed is WAY off. The weird thing is it's accurate up to about 35MPH then all of the sudden jumps up like 55MPH right when I start to accelerate past 35MPH. This has no effect on the cruise control thank goodness.
