jperecko
Diesel Ape
Yeah I was pretty surprised that it was that bad... that is the worst rust I have found on the truck yet... I am pretty sure it has been mostly a Cali or at least desert truck and have seen little more than surface rust everywhere. I think maybe someone managed to spill some brake fluid behind the vacuum chamber... that would explain how it got that bad.
Sorry, I am going to find a longer spring for my pump as I never changed it ,just the reservoir when I added hydro, it moans till you give it some rpm, so low flow/pressure is the most likely culprit.
