Austin86250
idaho
That’s pretty nice. And Cudos for the f6 fiber loom, heat shrink and relocated glow plug controller.
Thank you, my buddies truck it had a very bad factory harness. Weirdly enough the obs they connect one the driver side unlike bulls and bricks
So had to get idi diesels glow plug harness and was not ammused with the routing in the slightest so I redid 80% of it And combined it with the engine harness
I Get so sick and tired of bad wiring I don’t mess around much
I’ll end up putting a rubber fuel line on the edge so there is 0 changes wires can rub
Austin86250
idaho
That's great! If I was gonna point out any area of concern, though it's not necessarily a terrible thing, but you're going to need to put on 35-40lbs to balance the weight of the truck back out. I recommend little Debbie snacks, they can really help you stack it on quick. Especially if you eat them before bedtime, nothing adds bulk like eating before bed!
Funny you say that becuase truck is actually 1.5” lower on the passenger side
It’s not the trays fault but that’s what we first thought
KansasIDI
I hate printers
Wilsey, KS
I’m back around home as of today, and some shiny things arrived in the mail this week. I should have some pictures of such shiny objects in mock up tomorrow that I will post here. They are very much IDI related…
Thanks to R&D and @IDIoit, who both accepted my money in trade for their respective products of great function which are subjects of their amazing artistic talents.
I do need to go get some fasteners for said products, which will not be as straightforward as it should/could be, and not out of necessity. For the mock up I will use the old bolts.
KansasIDI
I hate printers
Wilsey, KS
Mocked it up on a frame with a bad engine and transmission, the V band on the up pipe sits up against the down pipe, but I should be able to modify the V band to clear.
I still need to clock the cold side housing for the intercooler, but since I don’t know exactly what I’m doing in that regard, I’ll do that later.
I’ll probably try to use a 17-19 6.7 PSD air filter system
R&D drop in 093 turbo
R&D 3” V band downpipe
IDIoit 2.5” V band bellowed up pipe
Much easier to mock up without a cab in the way. Should make actual install much easier.
KansasIDI
I hate printers
Wilsey, KS
It won't take much clearance. There won't be any movement after it's all installed in the truck.
Yes, I have gotten everything to clear properly now.
It will indeed be very solid once it’s installed. Shouldn’t have to worry about leaks at all.
Even though most of the hardware in this mock up iteration is new, it’s not what will be in the final install. Class 10.9 and grade 8 CAT bolts will be used.
Also need to get a new crossover pipe, the old one is cracked.
I wish I’d done a mock up with an E4OD, I could still do that yet tonight. The transmission dipstick tube is yet to be resolved. Cab clearance likewise. Since the cab and engine are yet to be removed from the 94, I can’t attend to that at this time. The engine is getting upgraded valve springs, factory turbo head gaskets, new IP, new injectors, deep cleaning and head studs at a later date.
I think I have the cold side housing where I want it, but it can be changed if necessary. Wastegate will obviously be adjusted far in the future, during early stage road tests.
The quality of these pieces is terrific. Props to IDIoit and R&D. Amazing work. We are all fortunate to have them, their knowledge, and their skills among us. Wonderful community this is.
I do have a couple of questions for Justin at R&D that I’ll call him about tomorrow, the downpipe seems short before it angles back toward the rear of the truck. But with no cab, it’s hard to tell. I would’ve thought it wouldn’t make that change until about midway down the frame rail.
The cold side housing is another thing. There are some tapped holes that aren’t plugged that confuse me. I think one might be for turbine speed, but that’s just speculation. I don’t actually know. It could be for boost, I don’t know where it leads.
I’m not convinced the other hole is a port, it might just be for mounting something. I’m sure Justin will know.
The turbo drain pedestal supposedly needs clearancing, according to R&D’s website and the included information pamphlet. I didn’t have to clearance it, there was plenty of space between it and the cold side housing mounting bolts. Being non intercooled may change that need, what with likely tighter tolerances, as there is quite a bit of play in the mounting holes of the pedestal. The turbo’s design allows it to be used as a drop in upgrade, which is a tall order compared to the relative sloppiness of intercooler piping.
I need to order an 093 install kit, with new O rings, gaskets and seals.
I’m excited for this project to come together. Should make some significant progress this fall and winter, with enough input this summer to keep it slowly moving along.
This summer may lead to a different nature of automotive project, that will likely be executed in a similar manner as my 91, smaller upgrades along the way, while using it.
Since I forgot earlier, I went on a dirt road cruise on the way to town. Sometimes I like to drive on new roads just to see what I can come across.
KansasIDI
I hate printers
Wilsey, KS
Well I ordered more parts tonight.
I ordered Hypermax's overpriced dipstick that relocates across the top of the transmission to the drivers side.
I have a Workhorse Customs fan and clutch kit ready to be installed.
Ordered a full fuel system from R&D.
Ordered an 093 install kit from Russrepair.
Ordered ARP head studs, head gaskets, valley pan, and valve cover gaskets from CDD.
abcdefg
