Danielle
No, it's not finished
Dirty Jersey
I didn't do much to the truck. I checked the air pressure in the tires (in the trailer tires too) and then got an early start on loading up for the weekend's trip.
I am so jealous of people living where they can just pack up their toys and go riding somewhere local. Every square inch of NJ is paved!
Selahdoor
Index Wa
Well, this wasn't today. In fact, it was exactly a week ago.
I blew a tire.
At 70mph. Surrounded by traffic.
Here's the tire. I took the pic as I sat on the side of the road waiting for someone with a jack. LOL
Here is a bit of explanation:
The green is all the tread that was blown off.
The red is all the steel cables that were blown out. (Took a lot of force to literally snap and rip those thick steel cables.)
The blue is where the tire split out the side.
And the yellow is where a knife was laying underneath the blown tire.
I was going down the highway, at a place where traffic gets real close to each other, and there is a lot of jokeying for position, because we are about to go around a curve, and onto a trestle.
Dangerous enough, without blowing a tire. People are NUTS!
Traffic was close in on me, all around. I'm talking less than a car's length ahead and behind and the same traffic in the lane next to me.
I was doing at least 72.
I was in the left lane. Nowhere to go over there, except down a cliff.
When this tire blew it was no "POP". It was KA-BLAAAAAM!!!! People probably heard it for miles around.
It was the kind of explosion that should have send the truck out of control. It lifted the back end up.
But here's the thing.
The truck settled down instantly, and became rock-solid in the steering, and rolling forward. And all that traffic disappeared.
It was like two hands came down. One grabbed the truck, and steadied it, and the other brushed all that traffic aside.
In those situations, time slows down. It's not just my imagination that the traffic 'disappeared'. This happened in a split of a split of a split second, that all that traffic was clear, around me. Vehicles cannot move or brake that fast. They were just gone.
And the truck acted like a hand was on it. Other than the split second of the back end jumping up, a bit, it settled right down, and drove just as solid as if nothing had happened.
I leisurely pulled over to the right, and off the road on the right. Nobody in the way, etc...
I was on my way.... To get new tires. LOL
Waited for the road rescue guy for a couple hours and STILL made it to the tire shop in time to get the new tires mounted.
If I had had a jack with me, I could have save 80 bucks, and some time, and changed it myself.
Last... When the guy jacked the truck up, and pulled the tire off, I kid you not, a really nice Gerber knife was sitting below the tire. The center of the blown tire was sitting directly on top of this knife.
The rescue guy got the knife as a gratuity. :D
While I can go riding straight from my garage, this weekend I'm going about 4 hours northwest into Nebraska.
Here's something that most people don't know or don't think about (probably don't know). The tire pressure is rated in PSI, pounds per square inch. Just to throw out numbers, if you're running 30 PSI in your tire, that's 30 pounds of pressure for EVERY square inch. If your tire tread is 6 inches wide, then across a 1" wide section of tread, you now have 180 pounds of pressure. The same goes for your sidewalls as well as the tread. Every square inch of sidewall has that same 30 pounds of pressure. I'm not going to try to figure out the surface area of a tire, so here's more numbers throwing. If you have 100 square inches of tire surface (10"X10"), you now have 3000 pounds of pressure. A 10"X10" area is NOT very big when compared to the overall surface area of say a 235/85R16 tire. Now take that 10"X10" area and put it at 80 PSI and you have 8000 pounds of pressure and it keeps multiplying over the whole surface of the tire. To say that you have a lot of pressure on the surface of your tires is an understatement. Plenty enough pressure to break the steel belts when there is some age or imperfection in the tire. Thinking of tires this way, you suddenly gain an entirely new respect for the job that our tires do and how they do it. Modern tires are really a marvel of technology.
Selahdoor
Index Wa
Yep.
Part of the saving grace for me there, was the fact I had them at 50psi, instead of 80psi.
They are 245/85R16.
And I think also a part of the saving grace was the intentionally smart move to mount that particular tire on the passenger side rear. Had I left it on the passenger front, I would imagine it might be someone else telling the story, and not I.
Scotty4
I blew a tire.
Thank God you are okay and finally got new tires!
In your situation, you're probably right. When I had one on the passenger's side blow out at 70MPH on the highway, it was on a two lane and the truck went into the right ditch really quickly. It was all that I could do to keep it in the ditch and out of the wheat field on the other side.
TNBrett
Middle Tennessee
About a month ago there was a mobile service tech that works for the hose shop I go to that died. The right front tire blew on his service truck on a two lane highway. Apparently he flipped a couple of times and was gone before anyone showed up on the scene. It was a pretty sad story.
Laine D
Northern California
I have a question for you guys. Today I tried to get my oil filter off of the oil cooler and it’s literally seized. I cannot get it off at all. I put new O rings on the cooler 2 years ago. If I pull the header off do you think I’m okay to re use the o rings?
Rayfish
